LCD screen is blank after first startup.
Dillon Hall
(@dillon-hall)
I just finished building my Original Prusa Mini+ kit, but when I turn it on, the screen lights up but is absolutely blank. I have tried unplugging the LCD cable from both ends and the screen turns off  and the fan starts to run. From what I understand the screen should instantly go to setup.
Posted : 15/10/2022 8:47 pm
Call on Prusa Support.
For support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Posted : 15/10/2022 10:35 pm
Zoltan
(@zoltan)
Member Moderator
RE: LCD screen is blank after first startup.
Reset knob push does not help?  Could be you are in dfu mode due to dfu pin shortcut. Contact support.
Posted : 22/10/2022 4:17 pm
