Is this a bug? I can't explain it's logic.
Prusa Mini +, through reasons of a cheap PETG filament, I need to use the Tune function to turn the temp up from 215deg to 230deg. I do this right at the start of the print as it's warming up from 170 for the first pass. Print results are absolutely fine as long as I do this.
I've discovered that after it prints the first layer (there's no raft), it will revert back to 215 deg!
If this isn't a bug, can anyone explain to me why it would do this?
RE: Is this a bug? I can't explain it's logic.
If you examine the filament settings tab in PrusaSlicer, you'll see that there are temperature entries for first layer and other layers. What is happening is that:
- You start printing the gcode with the temperature set to the 1st layer temp.
- You manually override the temperature.
- At the end of the 1st layer, the gcode has a temperature command that overrides your manual setting.
Of course you can do another manual override AFTER the first layer has completed.
Create a new profile for that filament in the prusaslicer and adjust temperatures there. If your sliced settings tell the printer to heat only to 215°C you are using a wrong profile anyway?
If you're going to use PETG, slice your model in PETG. Otherwise, the printer will run the program as if it were PLA.
