Is the Prusa Mini Hotend and All Metall Hotend?
Eric Eichstaedt
(@eric-eichstaedt)
Hey,
I was wondering if you can assume that the standard Hotend of the Prusa Mini is an All-Metall Hotend because the PTFE doesn't go all the way down to the nozzle.
Are there any other properties so that you can call a Hotend an All-Metall Hotend?
Greetings
Eric
Electrical EngineerWorking on master’s degree in electrical engineering
Publié : 31/07/2021 12:01 pm
PTFE Through heatbreak to rear of nozzle is not all metal
Hi Eric
If I recall correctly the section of the hot end from the bottom of the heatbreak upwards is PTFE Lined (Inside the melt zone),
Only the nozzle is totally metal. this is not an all metal hot end.
I believe the Bondtech Heatbreak upgrade,  provides a new heatbreak where the entire length of the melt zone is metal
this would make the bondtech mini hotend upgrade into an all metal hotend.
Other revised heatbreak options may exist.
Publié : 31/07/2021 2:04 pm
esaaho
(@esaaho)
Not even the Bondtech heatbreak is all metal
I have the Bondtech heatbreak and while it may provide other benefits, it does not make the hot-end all-metal. There is still a PTFE tube inside.
Publié : 31/07/2021 9:56 pm
Eric Eichstaedt
(@eric-eichstaedt)
Depends on the definition of All-Metall-Hotend
First, thanks for your answers.
I also upgraded to the Bondtech heatbreak and I thought the original Heatbreak was similar when it comes to the position of the PTFE Tube.
All-Metall means to me that there is no PTFE Tube in the melting zone and not no PTFE at all.
Publié : 01/08/2021 4:06 pm
BogdanH
(@bogdanh)
Bondtech heatbreak might look similar only at first sight. In functionality however, it's totally different:
1st -temperature wise, it actually decouples hotend and coldend (original heatbreak doesn't),
2nd -TPFE is located only inside coldent (in original heatbreak, PTFE goes all the way to heatblock).
In that sense, I don't care if it's "declared" as all-metal or not.
I highly recommend watching this video (explanation 5m:30s).
[Mini+] [MK3S+BEAR]
Publié : 01/08/2021 5:59 pm
2 personnes ont aimé
