Is leveling or calibration required when replacing the build plate?
[Rozwiązany] Is leveling or calibration required when replacing the build plate?
QUAK
 QUAK
(@quak)
I'm a beginner who bought a mini.I bought two types of build plates. Does this need to be adjusted every time I replace them?
Opublikowany : 20/08/2021 8:52 am
QUAK
 QUAK
(@quak)
I found the information I wanted.
https://help.prusa3d.com/en/article/steel-sheet-profiles_1955
Thank you very much.
Opublikowany : 20/08/2021 9:36 am
leveling
Posted by: @quak
It is highly recommended.  No two sheets are identical.  They may be close and it is not worth ramming the sheet and permanently scarring it.
Opublikowany : 20/08/2021 9:48 am
