Is Is this a filament popping out of the bed?
YigalB
(@yigalb-2)
There is a strange green wire popping out of the side of the Prusa Mini bed. Is this a filament? It is not easy to pull, I am afraid to force it out.
Opublikowany : 23/09/2021 9:30 am
sheet
Can you remove you sheet and show a photo without the print sheet?
Opublikowany : 23/09/2021 9:46 am
jcjames_13009
(@jcjames_13009)
Sheet edge ?
Hi
It looks to be a king of glue residue from the edge of the sheet. Not a filament
My guess is that it's the glue used to stick the protective surface that has dripped during lamination process. Personnaly I won't take it off. Just cuts the part already taken off
I have it also (but still stuck) on my smooth plate not on the textured one
JC
Prusa MINI+ at home / Prusa MK3S+ in the Fab Lab / You can have a look at my designs here printables.com
Opublikowany : 23/09/2021 10:28 am
