Initial setup wizard open every time after start up
steven z
(@steven-z)
After flashing the new firmware. This setup wizard keeps popping up every time power is on the machine. I flashed back to the older version it's still the same. What might be the cause of this? Thanks
Opublikowany : 26/12/2022 12:22 am
William
(@william-2)
RE: Initial setup wizard open every time after start up
Did you do the wizard before? I had a similar issue (I did the wizard and x weeks later after some steps this happens again) and reported it to the support. Unfortunately it can't be reproduced.
What I did: I flashed the (at this time 4.4.3) newest FW and did the wizard again. Then this issue never came back.
Opublikowany : 30/12/2022 5:53 pm
