I would like to be able to use the entire build tray but I am forced to print much smaller parts.
Turnert
(@turnert)
I'm not sure how to fix this issue. This stl rectangle fits my co-workers Prusa and prints fine. When I bring it into my Prusa Slicer, it is to large for the build tray. Is their a setting I need to change? I would like to be able to use the entire build tray but I am forced to print much smaller parts.
See picture below
Thank you for any help you can give me.
Opublikowany : 27/12/2021 3:47 pm
MysDawg
(@mysdawg)
RE: I would like to be able to use the entire build tray but I am forced to print much smaller parts.
Posted by: @turnert
Does he have the same model of printer? Otherwise, you might consider resizing for your build plate.
Opublikowany : 27/12/2021 6:45 pm
Lichtjaeger
(@lichtjaeger)
The part is scaled for an i3 build plate, but your selected printer is a Mini.
Opublikowany : 27/12/2021 7:01 pm
Turnert
(@turnert)
Thank you very much!!! This helps a lot 🙂
Opublikowany : 27/12/2021 7:46 pm
