I need to change "Live Adjust" nearly every print - is this normal?
Dillon Nichols
(@dillon-nichols)
Like the title says, I can be printing a new revision of the same object shortly after the other one with the same filament and bed sheet and I may have to change the Live Adjust up to like 0.4 in one direction or the other to make the first layer perfect. Back when I got the printer it was so bad that I maxed out the adjustment at -2.0 so I readjusted the PINDA and superglued it in place because I thought it was moving. Could there be something else wrong with my hardware? I think I followed the assembly correctly (it's simple and only a few steps) and once the first layer is down, my prints look fantastic. Has this happened to anyone else?
Veröffentlicht : 16/11/2020 7:41 pm
rockytoptim
(@rockytoptim)
RE: I need to change "Live Adjust" nearly every print - is this normal?
I have the same issue.  I have found its much better if you pre heat the MINDA.  Once the nozzel and bed get to bed leveling temp I part the nozzle at x 90 y90 z 1.5 and let it sit there for two minutes.  I also let my maching cool down to 25C before starting another print.  Seems to work for me.  95% of the time I don't need to change live z during the first layer going down.
Veröffentlicht : 18/11/2020 6:41 am
herbert
(@herbert)
Have a look at these github issues
A possible fix, if nothing else helps
https://github.com/bbbenji/PMSBLM
Veröffentlicht : 18/11/2020 12:16 pm
Dillon Nichols
(@dillon-nichols)
Thanks for that information. I can deal with it, but it's a pain point of the printer. If it wasn't for this, I could just hit print and walk away.
Of course, this printer is sooo much better than my old one, but not the perfect printer yet.
Veröffentlicht : 18/11/2020 12:35 pm
withey89
(@withey89)
I think there must be an issue with production of the MINDA sensors. I had same issue. Get in contact with Prusa and get it replaced, I got mine replaced and no issues since.
Veröffentlicht : 18/11/2020 1:54 pm
