I need Help
EffectStyle
(@effectstyle)
I need Help
I Install the new Bondtech extruder & heat-break at first i hat no problems.
the Bondtech extruder works fine but .
i printet for few days i got a cloging in the heat-break i clean it try loading and purge but do not purge removing the tube and and check i`ts clean.
i have try to push the filament bye hand but i`ts nor coming out whit the tube inside and whit out
Best Answer by BogdanH:
There can only be two reasons why filament doesn't come out (if pushing filament by hand):
A -nozzle or heatbreak is clogged
B -nozzle temperature is too low
Napsal : 05/12/2021 1:23 pm
BogdanH
(@bogdanh)
RE: I need Help
[Mini+] [MK3S+BEAR]
Napsal : 05/12/2021 5:16 pm
sandysasmita
(@sandysasmita)
RE: I need Help
check the PTFE tube inside the bondtech heatbreak. is it shrinking? if yes, that is because there is not enough cooling, make sure you apply enough thermal paste on the heatbreak. and tightened three grub screws.
Napsal : 05/12/2021 5:29 pm
EffectStyle
(@effectstyle)
RE: I need Help
tnx for the help some left overs in the heatbreak
Napsal : 12/12/2021 12:47 pm
