How to see MINI's clock?
Crawlerin
(@crawlerin)
Is there a way to check its clock? I was putting it in new enclosure, after network was connected it picked up NTP and time was OK as UTC +1, but after few consecutive prints and filament change I noticed it picked up weird time. Still showing UTC +1 but now it lives 9 hours in the future. I restarted it while ago but I do not see how to display actual clock on MINI. I want to check its clock to see if print finish time makes sense.
Edit: 4.2.1 FW
This topic was modified 5 years ago by Crawlerin
Posted : 18/01/2021 7:06 pm
Gordon W
(@gordon-w)
RE: How to see MINI's clock?
I don't think you can, I think it picks up the time from an NTP server.
Edit: See https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/prusa-mini-ntp-server-used
Posted : 18/01/2021 10:04 pm
remington
(@remington)
It would be nice to have the option to change “time till” and “finish at” in the options somewhere, rather than automatically changing to “finish at” when plugged into the network, especially with the problems shown in this thread which I’ve also seen on my Mini too.
Posted : 19/01/2021 8:12 am
ChillyPenguin
(@chillypenguin)
@remington
My solution was to block NTP at the router.
Port: 123
Protocol: UDP
Posted : 19/01/2021 8:21 pm
Zach Oliver
(@zach-oliver)
On the MINI there isn’t a direct “show me the system clock” function in the menus, so you can’t just display it like on a PC. What happens under the hood is:
Posted : 02/09/2025 11:43 am
