how much should the heat block pivot?
my heat block pivots probably 10-15 degrees left and right when it's hot. Is that normal or did something break? I can't tighten the 3 screws holding the heatbreak any more and the heat block seems stiff when at room temperature.
Postato : 01/12/2024 9:32 pm
