Homing without end stops possible on other printer control board?
[Solved] Homing without end stops possible on other printer control board?
print the world
(@print-the-world)
I have a Mini and love the fact that it does not use any physical or optical end stops.
I'm planning my next printer build and I would love to integrate this feature into it, but ideally with a Duet 3 board.
Is it possible to set up homing like this on another board? Is this a feature of Marlin, or something that only functions on the control board of the Mini?
Thanks! 🙂
Napsal : 17/01/2021 5:44 am
print the world
(@print-the-world)
RE: Homing without end stops possible on other printer control board?
I posted to soon... 😓
Found the answer after a bit more searching
https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
https://marlinfw.org/docs/gcode/M914.html
Napsal : 17/01/2021 6:01 am
keithywhites
(@keithywhites)
im pretty sure any board with at least 2209 drivers can use sensor less homing.
Napsal : 26/01/2021 11:42 pm
