Help removing brass fitting on top of hotend
I think i have a clog, but the only info on replacing/checking the hotend ptfe tube on the knowledge base involves unscrewing the brass hitting which is on top of the hotend. The images on the guide look like they have a different 3d printed cable guide piece next to the heatsink, though, and mine is fully in the way of any rotation of the brass fitting. No matter what I do, unless I completely dismantle and detach the whole hotend which I'd really like to avoid, I can't unscrew it. Has anyone else done this successfully?
Napsal : 14/10/2021 12:55 am
Do you have a picture of your machine, in particular the fitting on top, so we know more specifically how it's different from what's in the knowledgebase?
Napsal : 14/10/2021 1:43 am
