Yeah I used some a few months ago but it was in kinda bad conditions so I figured it was no good, and it printed terrible, much like this time.
I used some when I first got it and it was ok but it had a lot of inconsistency, sometimes it bubbled sometimes under extruded.
Now that I think about it, never had a really quality print with Hatchbox, which is weird because I've seen Prusas use it just fine before.
I will have to try the oven trick.
I will give the calibration one more shot with the Hatchbox.
RE: Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
yeah try the oven trick i use esun pla+ i find that stuff really good
glad that your printer is up and running and after 4 pages we came down to a soulution
cool I will have to look into that. Should I try the oven trick before doing another first layer? Currently running the cube test print.
honestly lol
was a great learning experience though, a ton of new troubleshooting steps that I had never done so at least there was some learning.
do the oven trick first 5 miniuits no less no more then do first layer and let me know how it goes yes sorry if some of it seemed confuising
Will do. No problem, I appreciate the help.
all good the if the oven trick dosent work then heat printer to 260 degress run the fillament through a bit then col down printer to 220 and try print
ok, also is that oven trick in Celsius (80c)
yes
American oven moment lol
hahaha lol
don leve it in too long only enough to draw out the humity
Yeah I ran it through the oven, ill test in a minute when the box is finished.
that is not right
what was your tmp at
215c
could try running it at 220c
i mean temperature
