FW 6.0.0 Prints pause constantly, and network interface is unreliable
LittleNeutrino
(@littleneutrino)
Mitglied
Every since the FW 6 update I am simply unable to actually use the printer.
I am running the full release version of the firmware on a pre-order Prusa Mini that has been upgraded to the +
I am using PrusaSlicer 2.7.4 to create my gcode files.
I will get about 10-15 minutes into a print and it will just pause, stays heated up, sometimes the print head will move to the side and ask me to hit continue, othertimes it just pauses right on the print fully heated and just melts the print.
as far as the network goes. If you try to send a GCODE file to the printer via the prusaslicer or upload via connect or link the interface will disconnect at exactly 11% every time and then the printer shows as offline (even to my network hardware), I have tested this both wired and wireless with the same result.
I have had this thing for years and its a workhorse. its a shame that as of right now its completely unusable.
Yes i did a fully factory reset and pulled a fresh download off the website to do the firmware install off of the USB.
Veröffentlicht : 29/04/2024 11:37 pm
_KaszpiR_
(@_kaszpir_)
RE: FW 6.0.0 Prints pause constantly, and network interface is unreliable
Just do a firmware downgrade, then ?
Veröffentlicht : 30/04/2024 7:02 am
LittleNeutrino
(@littleneutrino)
Mitglied
I would rather there were an actual solution, the network issues have persisted since the 5 branch of firmware, but the pausing is new with 6
Veröffentlicht : 30/04/2024 1:00 pm
