First Layer Inconsistent
Roguebyte
(@roguebyte)
After performing the mesh bed analysis and running first layer calibration, the left size of the bed is higher than the right. So I cannot get the whole print bed with a consistent first layer.
I thought the mesh bed analysis was supposed to take care of this?
I have the SuperPINDA and Bondtech heatbreak and extruder.
Postato : 12/01/2021 3:10 am
ForrestFunk
(@forrestfunk)
RE: First Layer Inconsistent
I also have problems using the far left side of the bed (only tested with PETG yet). I even did the silicon bed leveling mod. See here:
https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/prusa-mini-silicone-bed-leveling-mod/paged/10/#post-340957
Postato : 14/01/2021 7:32 am
Roguebyte
(@roguebyte)
@forrestfunk
So even after the silicon mod your bed is not level and the mesh bed probe doesn’t compensate?
Postato : 14/01/2021 6:13 pm
ForrestFunk
(@forrestfunk)
@roguebyte
no that's not what I'm saying. With the mod it is easy to get your bed fully level (as you can see in my first picture - possibly even better with more time). But after having it completely level, PETG still wasn't sticking at the very far right side (close to z-axis). In the other thread I assume this is somehow related to the SPINDA being not really close to the far right side. My results were better when I "lifted" the bed on the far right side by ~0.3mm
Postato : 14/01/2021 7:14 pm
Alex Hung
(@alex-hung)
If it is just a tilt in the x-axis, there's a knowledge base article that shows you how to adjust the x-axis to compensate. I used it to get my x-axis pretty close to parallel to the build plate.
Postato : 15/01/2021 1:21 am
Roguebyte
(@roguebyte)
@alex-hung
Thanks, gave this a try and now aobut 80% of the bed is consistent with first layer calibration.  The X-axis is still higher on the far right side.  At least this is a step in the right direction.
Postato : 18/01/2021 6:35 pm
1 persone hanno apprezzato
