First layer callibration issues
polo5959
(@polo5959)
Hello,
I have two issues with my first layer calibration layer. note that I use a 0.8 nozzle but I have the same issue with the 0.6 one.
-First the line is not continuous see picture. It seems that the filament is not going out quickly enought. I tried different layer height and always the same result.
-Second issue is that the motors are doing a weird noise when moving back to there position a sort of Cogging sound. But that only happen when going back to the position 0, it doesn't happen when it's printing.
Has anyone experienced this issue before?
Thanks
Veröffentlicht : 28/01/2024 8:08 pm
Tysonsw
(@tysonsw)
RE: First layer callibration issues
Which firmware are you using?
With the 5.1.2 firmware you can open Settings and set which nozzle size you use. First Layer Calibration is calibrated for a 0.4 nozzle. This might have achanged with the option of setting nozzle size in the Settings menu.
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: [email protected]
Veröffentlicht : 30/01/2024 8:49 am
polo5959
(@polo5959)
Hi Tysonsw,
Thanks that's probably the solution, I didn't know you could set the nozzle size for calibration, will try this week end.
Best
Veröffentlicht : 31/01/2024 1:06 am
