Firmware update gone wrong, stuck on error #12608
I was trying do update te firmware and start with the pre file but, then the printer get stuck in this error #12608 and i try to change the USB, format the USB, and nothing works.
I was trying to pass from the 4.3.4 version to the 4.4.1
I don´t know what elses i can do to bring the printer back again
Opublikowany : 15/12/2025 11:24 pm
Did you follow https://help.prusa3d.com/article/firmware-in-the-internal-flash-corrupted-12608-mini_381775 ?
Make wure to format a pendrive as MBR partition format, and wipe all files from it, put only one firmware file on it ( can be he old ine).
Opublikowany : 16/12/2025 8:52 am
