[Firmware build] "region `FLASH' overflowed by 35460 bytes"
remotelove
(@remotelove)
Hello. I have just configured Visual Studio Code and am able to get through the build of the current master branch of the firmware. Unfortunately I am getting a 'region `FLASH' overflowed by 35460 bytes' error when linking. Any quick fix to this?
FYI, I cannot post the log snippet for some reason since this sites WAF thinks I am trying to inject malicious code! LOL!
Opublikowany : 18/11/2020 8:03 pm
RE: [Firmware build] "region `FLASH' overflowed by 35460 bytes"
Hi Matthew,
Personally I don't mess with the firmware, so hats off to you...
whilst I can't directly help with this issue I have approved your post so others can see it.
If you have a file that will not attach tot he forum, you can zip it into a compressed file, and attach the zip file...
However at this time I suggest that you see if anyone can help you on here and if they think the WAF File will be useful, you can attach it at that time.
Opublikowany : 18/11/2020 8:18 pm
