Firmware 6.2.6 just ate my usb stick?
(probably not, but it could?)
This evening, I noticed the new firmware from inside PrusaSlicer / PrusaConnect. The printer accepted the file (uploaded fine). When I hit flash-button, the printer reboots, but didn't flash/boot/recover. The screen said "looking for BBF..". I pull the USB stick and discover it has lost both its content and its file system (shows up as RAW in Windows).
I re-format with FAT32 (8GB stick), load the BBF-file manually back into it, from my computer. Returned into the printer, and it is flashing successfully. But - after another reboot, the stick is broken again.
It may just be a broken usb stick, but I thought I should post the experience, in case this is something you notice too.. Too much of a coincidence? I guess I have to do some more digging into this.
