RE: Filament stuck in extruder
Remove the tube coupling and see if you can pull out the filament with needle nose pliers,
if that is not possible,
take a drill of 1.5 mm and try to push the filament out with the back of this drill.
Opublikowany : 18/11/2022 2:29 pm
