Filament stop came out after 30 mins print
atomleef
(@atomleef)
After load and print multiple times after 30 mins filament stop came out event extruder still do it's job. Cannot unload then I need to remove Bowden scew from extuder and hot end to remove it manual. Before this happen mini never have problem for 40 hrs print. I used to print 6 hrs long print with no problem.
This is my condition
Print in 33c
Print with and without enclosure fail
Esun pla
Slice with prusa slicer
Use prusa esun preset 0.2 quality
Swap between flex and pla for a while(eact 1 hr print)
This is what I try
Cold pull
Clean extruder gear
Add more tension to extruder
Push pla manually - seem work fine in 215c
Use needle to clean nozzle
After all process it still fail after 30 mins print
How to resolve this, please help.
Here my gcode, unload filament shape in attachment
https://drive.google.com/file/d/1shXZLxJR5NRya0AgiOHDOvPbET-sqxnu/view?usp=drivesdk
Thank you in advance 😊
Ce sujet a été modifié il y a 6 years par atomleef
Publié : 06/07/2020 1:52 pm
assist
(@assist)
RE: Filament stop came out after 30 mins print
What was the ambient temperature when this happened?
I believe that the room may have been too cold to allow the print to take place in good condition.
Publié : 07/07/2020 10:02 am
atomleef
(@atomleef)
@assist thanks for reply
Room temperature is 30-33 degrees Celsius
I live in Thailand 😄
Still hopeless about this problem😭
Publié : 07/07/2020 4:30 pm
atomleef
(@atomleef)
I guess the problem is ptfe tube damage because I found piece of plastic at hot end base. I need few additional procedure from prusa suggestion
eg
I cannot remove brass tube that attached to hot end because of fan part is obstacles to the wrench to fully react the brass tube.
AfterI found a plastic a ptfe base prusa do not give a suggestion how to remove it then I need to heat hotend up and use a pin to pick it out.
The brass tube also make me confuse because both side is different and prusa do not which side is correct to put in hotend, which side to put to filament tube.
I not yet test print hopefully it will be fine
Publié : 11/07/2020 11:03 am
atomleef
(@atomleef)
I just finished my print, ptfe damage is problem. After change the tube printer work fine now.
Publié : 11/07/2020 5:37 pm
