Filament Sensor Turning Off by itself in menu
3DB
 3DB
(@3db)
Hello,
Is anyone else having/had trouble with the filament sensor turning itself off? By that I mean I have set it to on and know that it's working however it then seems to turn its self off in the menu. I know it's doing this because when I do a filament swap, I do not get the message that is triggered by the filament sensor saying make sure filament is inserted
It seems a bit pointless if it's going to turn itself off without me knowing!
Any solution?
Postato : 22/09/2021 9:27 am
Utenti
Sensor turn off
Does it happen with every swap?  What firmware are you using?  I will check tonight but I am not sure I have seen this.
Posted by: @dburn9
Hello,
Any solution?
Postato : 22/09/2021 10:01 am
3DB
 3DB
(@3db)
Sensor turn off
Posted by: @cwbullet
Posted by: @dburn9
Hello,
Any solution?
To be honest I'm not sure when it does it, I just happen to notice when I have to do a filament swap. Luckily times where it's happened is when the filament isn't low but I just don't want it to run out whilst printing and not be detected.
I'm using stock firmware,  4.3.2
It seems it's not saving my settings. I'm not sure how/why it would change from yes to no in the menu once set
Thanks for the response
Postato : 22/09/2021 10:23 am
Utenti
Suggestion
I would turn it on and Do another filament swap and see.  If it does not, it was a fluke and i would not worry about it.
Postato : 22/09/2021 10:28 am
3DB
 3DB
(@3db)
User Error
Ok, I feel stupid now
I've just realised it was my fault...
If inserting the USB stick without filament loaded it gives the warning message about it not being loaded, I must've pressed ignore which disables the sensor...
At least it's now solved!
Postato : 22/09/2021 1:21 pm
Utenti
Thread
There are not stupid mistake.  Each one is a learning lesson to share.  Hopefully, your thread will help others.
Posted by: @dburn9
Postato : 23/09/2021 12:18 am
jcjames_13009 hanno apprezzato
