fan not spinning.??
Chriske
(@chriske)
fan not spinning.??
Hi
Although I successfully tested the fans of my Mini I got the message that the partscooling fan does not rotate when starting the second layer.
What could be the problem..?
Thanks guys...
Napsal : 22/04/2025 12:48 pm
_KaszpiR_
(@_kaszpir_)
RE: fan not spinning.??
https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/hotend-fan-not-spinning-check-it-for-possible-debris-then-inspect-the-wiring-error/ maybe?
Napsal : 23/04/2025 6:15 am
Chriske
(@chriske)
In the link Kaszspir wrote :
Napsal : 23/04/2025 7:06 am
Chriske
(@chriske)
You should notice that the problematic filament type has lower minimum fan speeds, so just go and bump them accordingly and save the profile and test it. If I remember correctly set for the Prusa Mini minimum fan speed to at least to 25%.
Since I did it I had no errors of this type.
Standard speed for PLA is set at 100% for the Mini Printer.
Napsal : 23/04/2025 7:14 am
_KaszpiR_
(@_kaszpir_)
Look car fully at the description if the auto cooling from the picture you atttached?
Napsal : 23/04/2025 9:51 pm
Chriske
(@chriske)
Thanks for your reply
Napsal : 24/04/2025 7:36 am
Chriske
(@chriske)
Could you explain what you're trying to say, should 'auto cooling be on or of....?
I also have a MK3 and never had any issues with cooling settings at all.
Napsal : 24/04/2025 7:38 am
Chriske
(@chriske)
changed a few things in Prusa Slic3r to no avail. Every single time the print stopped after its first layer.
So i disabled the 'fan check' in the printer itself : problem solved...!
Napsal : 27/04/2025 7:15 am
