Error: MINTEMP
Josiah
(@josiah)
Error: MINTEMP
The fun continues. I was having MinTemp errors last week but was able to print some small things. Now it is erroring at the very start of prints. Hoping a new thermistor (or whatever they called it) helps, but not holding my breath.
I have more pictures and a video if anyone is curious.
Postato : 21/10/2020 4:31 pm
MCMuckle
(@mcmuckle)
RE: Error: MINTEMP
I also get MINTEMP error.  I got one after a few weeks of not using the Mini.  It was resolved by using a hairdryer to up the temp of nozzle and bed (I live in a draughty old farmhouse, in Scotland...).  However, after removing, cleaning and returning the nozzle it has become unfixable.
How do you know whether the thermistor is damaged?
Postato : 21/10/2020 5:30 pm
MCMuckle
(@mcmuckle)
RE: Error: MINTEMP
In addition to my above fellow request for assistance with MINTEMP error this is what I see
Postato : 21/10/2020 5:37 pm
RE: Error: MINTEMP
@mcmuckle
You can check the internal resistance of a thermistor with a multimeter. The value should be measured at an ambient temperature of 25 degrees C. should be about 100kohms. The polarity of the measuring tips does not matter when measuring a resistance.
Simply remove the plug from the printerboard and measure.
simple multimeter
Postato : 21/10/2020 5:57 pm
MCMuckle
(@mcmuckle)
RE: Error: MINTEMP
Thanks for the suggestion.  As it happens I have a simple multimeter.  Now I just need to work out where to touch the probes...
If I make any progress I'll post back the solution...
Postato : 22/10/2020 8:28 am
Thunderbird
(@thunderbird)
RE: Error: MINTEMP
i also have this error
started happening after i flashed firmware to 4.2.1.
had 4.0.5 before and it worked perfectly fine
Postato : 29/10/2020 12:25 pm
Thunderbird
(@thunderbird)
RE: Error: MINTEMP
i tried flashing it back down, 4.1.0 had the same problem, 4.0.4 made the bed teeth jump in calibration and watchdog out, and now i have the same issue in 4.0.5
i dont know what is going on, but its pretty demoralizing
Questo post è stato modificato 5 years fa da Thunderbird
Postato : 29/10/2020 12:35 pm
RE: Error: MINTEMP
@mcmuckle
here a short introduction:
Postato : 29/10/2020 4:24 pm
Oboto
(@oboto)
RE: Error: MINTEMP
I have a similar problem with my mk3s (self build kit) that I have for about 2 months now. This first four weeks everything worked just fine. But after the firmware update I get a Bed Mintemp error at point 7 of the z calibration procedure (the one that the printer does before every print).
The printer request me to restart. After that it works just fine.
So I believe it is not a problem of broken cables or sensors, because the error occures exactly at the same point of the procedure and only once. After restart it proceeds throught the z calibration without any problem and finishes the print job.
This is very annoying, because it costs me extra minutes very time to restart, reheat and start the print job again.
I tried reinstalling the firmware - but it didn't help. I didn't try going back to the previous firmware, because it feels wrong somehow. But if that is a suggestion I would give that a try.
Postato : 30/10/2020 3:38 pm
Thunderbird
(@thunderbird)
RE: Error: MINTEMP
i spoke with support, described my symptoms and they said that it indeed is the thermocouple acting up and sent a replacement...
in my case i think its the wires to it being damaged because its not consistent and usually after the bed moves
Postato : 30/10/2020 3:51 pm
MCMuckle
(@mcmuckle)
RE: Error: MINTEMP
@karl-herbert
Thank you for the video.  I acquired a multimeter and by testing have established that the hot-end thermistor is most likely broken as when I remove the plug from the board and test across the two terminals I get a reading of 1.
To be honest I am disappointed in how delicate this part of the Mini seems to be.  I only followed the instructions to remove and replace the nozzle.  I guess I will have to order and fit a new hot-end thermistor...
Thanks
Postato : 30/10/2020 5:05 pm
RE: Error: MINTEMP
@mcmuckle
1 means infinite resistance, i.e. thermistor or cable/s defective. I assume that the problem will be solved with a new thermistor.
good luck with the installation and take care of the sensitive wires 👍
Postato : 30/10/2020 6:18 pm
MCMuckle
(@mcmuckle)
RE: Error: MINTEMP
I had a chat with customer support and they have sent me a replacement thermistor.
Although I was disappointed with the thermistor I am impressed with the customer service!
Postato : 31/10/2020 11:46 am
1 persone hanno apprezzato
