Erratic axis movements, then print slows to a crawl and stops.
tom_drcy
(@tom_drcy)
I'm having issues on some prints where as the print progresses the extruder movement starts to become erratic, moving away from the print in x, y and z directions. This gets more common with increasing layers until the movement begins to slow down and the nozzle starts to hit the print. The print speed then slows to a stop and freezes.
It happens about every third print. I have no idea what it could be. Any suggestions?
Best Answer by MadCyborg:
Do you print of an USB stick? Maybe try another.
Postato : 09/04/2021 9:35 am
MadCyborg
(@madcyborg)
RE: Erratic axis movements, then print slows to a crawl and stops.
Questo post è stato modificato 5 years fa da MadCyborg
Postato : 09/04/2021 12:07 pm
tom_drcy
(@tom_drcy)
@madcyborg
Good shout, I'll give that a go over the weekend, my next few prints are loaded on a second USB memory stick.
Thanks.
Postato : 09/04/2021 1:14 pm
tom_drcy
(@tom_drcy)
@madcyborg
Haven't seen the issue since switching from the USB supplied with the printer to a spare I had lying around. Cheers for the suggestion. Very much appreciated.
Postato : 12/04/2021 7:45 am
