dc charger
druckerei
(@druckerei)
dc charger
Hi, i have a prusa mini i have not used for a couple of years and i would love to use it. I lost the dc adapter somehow (still have a few crates of cables to go through to maybe find it) I would like to know if there is an alternative to using the original one, and where i might be able to buy an original one if there is no workaround and i dont find it. Thanks!
Veröffentlicht : 06/03/2025 3:43 am
RE: dc charger
https://www.prusa3d.com/product/external-psu-24v-150w/
Veröffentlicht : 06/03/2025 7:46 am
mark
 mark
(@mark)
RE: dc charger
Alternative (cheap) chargers often are not UL or ETL listed and don't have the same safety measures (isolation between high and low voltage sections, protective circuitry) and are often overrated. Since this is a high duty cycle application, running for hours at high levels, I'd go with the original. It also uses a somewhat unusual connector.
Regards,
Mark
Veröffentlicht : 06/03/2025 8:47 pm
