correction of steps / mm
Good evening to all, I'm Francesco and I'm writing to you from Italy.
I write because I have a problem with my prusa i3 mk3s. I printed a 20.00 mm cube per side to perform the steps / mm calibration.
The X side is perfectly 20.00 mm, the Y side is 19.90 mm and the Z side is 20.10. What are the original steps / mm of a prusa i3 mk3s? Last question how can I change the correct steps / mm on the prusa?
Many thanks in advance.
Francesco
Publié : 30/11/2019 7:50 pm
