Constant buzzer beep sound when power is on
kalle
(@kalle-2)
Hello
My MINI+ beeps constantly. It's the buzzer on the back of the LCD module. It starts instantly when I power it on and doesn't stop until I cut the power. Nothing I do in the software, including flashing the firmware, has any effect. I'm thinking it must be a hardware problem, but I have double-checked the cabling.
Any ideas on what could be going on here?
Opublikowany : 18/07/2021 9:58 am
Support
Posted by: @kalle-2
Hello
It might help if you upload a short video.  Either way, I suggest contacting support by chat on the eShop.
Opublikowany : 18/07/2021 12:53 pm
1 ludzie polubili
Zoltan
(@zoltan)
Member Moderator
beep
It is that issue from the beginning?
Do you have a new printer still under warranty? it could be a shortcutted end circuit or controller output, which makes the sound continuous.
Contact the support via e-shop chat.
Opublikowany : 18/07/2021 2:10 pm
