Connectors Diagram for Buddy board
Olli
 Olli
(@olli-3)
Hey,
I wanted to connect lights to my buddy board, but I can't find a good connection for 24V of AUX Power.
Does someone have a complete labeled connection like this one I pulled from RepRap for the Einsy?
Thanks, Olli
Opublikowany : 29/02/2020 1:41 pm
1 ludzie polubili
NibMaker
(@nibmaker)
RE: Connectors Diagram for Buddy board
https://github.com/prusa3d/Buddy-board-MINI-PCB
This was the best diagram I found when I was searching the other day. Specifically this link:
http://htmlpreview.github.io/?https://github.com/prusa3d/Buddy-board-MINI-PCB/blob/master/rev.1.0.0/ibom.html
Opublikowany : 01/03/2020 3:58 am
TeRaXion
(@teraxion)
Did you find a good connection to get 24V DC?
I need one too 🙂
Opublikowany : 08/07/2020 9:00 pm
1 ludzie polubili
biggie_ticat
(@biggie_ticat)
ANyone have any luck? Would like to see something on this too, could use some "work lights" over the bed, would be nice to power from the buddy board if a pin connector is available.
Opublikowany : 10/07/2020 11:05 pm
1 ludzie polubili
Lennart
(@lennart)
Bumping a thread. Anyone had luck in the past months? Is there a way to connect to the 24v rail without soldering?
Opublikowany : 17/10/2020 7:30 am
ignacmc
(@ignacmc)
One idea could be to prepare a small Y split cable and connect it between the PSU and the printer...just to get a male and female appropiate conectors and some wires....
Opublikowany : 20/10/2020 9:10 am
Lennart
(@lennart)
I understand your idea but most of the time you want the other supply when the system turns on. Not when you plug in the power supply 🙂
Opublikowany : 20/10/2020 11:08 am
rasmus.kjeldsen
(@rasmus-kjeldsen)
I didn't want to solder to the Buddy board, so I soldered a wire to one of the fuses. Note that it is soldered to the side of the fuse, otherwise it doesn't fit into the socket.
Opublikowany : 02/11/2020 3:21 pm
kiklhorn
(@kiklhorn)
I bought a similar one (fuse tap, fuse splitter) on Aliexpress years ago: https://dratek.cz/arduino/2177-adapter-na-pojistky-do-auta-micro-tap-12v-10a.html
The first fuse works as before, and the second ends by wire.
Sorry to have no better photo now.
Opublikowany : 20/11/2024 9:54 pm
