Connectors Diagram for Buddy board
Hey,
I wanted to connect lights to my buddy board, but I can't find a good connection for 24V of AUX Power.
Does someone have a complete labeled connection like this one I pulled from RepRap for the Einsy?
Thanks, Olli
RE: Connectors Diagram for Buddy board
https://github.com/prusa3d/Buddy-board-MINI-PCB
This was the best diagram I found when I was searching the other day. Specifically this link:
Did you find a good connection to get 24V DC?
I need one too 🙂
ANyone have any luck? Would like to see something on this too, could use some "work lights" over the bed, would be nice to power from the buddy board if a pin connector is available.
Bumping a thread. Anyone had luck in the past months? Is there a way to connect to the 24v rail without soldering?
One idea could be to prepare a small Y split cable and connect it between the PSU and the printer...just to get a male and female appropiate conectors and some wires....
I understand your idea but most of the time you want the other supply when the system turns on. Not when you plug in the power supply 🙂
I bought a similar one (fuse tap, fuse splitter) on Aliexpress years ago: https://dratek.cz/arduino/2177-adapter-na-pojistky-do-auta-micro-tap-12v-10a.html
The first fuse works as before, and the second ends by wire.
Sorry to have no better photo now.
