Configure a profile in Cura
omri
 omri
(@omri)
Hi everybody,
I was trying to set a profile for the Mini via Cura. Started the print with the same gcode the prusaslicer has. The measurement of the 16 points went fine, also the first line for purging, and after this - nothing.. the first line I was trying to print from the file was few millimeters of plastic then a blob and the printer xyz was at a stop while the extruder continued to extruded material and increase the blob size until the point I had to stop it. What am I doing wrong?
Do I need to configure something special with the mini except the build size and nozzle diameter? I have several printers at work and two at home that work with cura. any advises?
Thanks in advance.
Napsal : 04/04/2020 4:52 pm
