Configuration file prusa_printer_settings.ini
pep
 pep
(@pep-2)
In my house I have perfectly configured the wifi module. At work I have the following problem: Wi-Fi also requires specifying a user. How can I enter this data in the prusa_printer_settings.ini file? In the documentation it only contemplates specifying: network name and password. I need to specify also user name. Thanks to anyone who can help me.
Napsal : 20/12/2022 6:11 pm
M_Trouvé_FnR
(@m_trouve_fnr)
RE: Configuration file prusa_printer_settings.ini
Hello Pep,
did you solve the problem any way?
Kind M
Napsal : 27/03/2024 8:58 am
_KaszpiR_
(@_kaszpir_)
If your wifi requires username then usually it requires 802.1X - so it's something like WPA Enterprise with EAP, which is quite commonly used with Eduroam.
AFAIR Prusa printers firmware do not support this, so you have very few options:
- ask network admins to add special exceptions to the device usually via WIFI/Ethernet MAC address and assigning to specific restricted VLAN
- use additional device which supports it - such as Raspberry Pi Zero W https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/eduroam-network-access/
- as above but make it a bridging network so that some wireless client connects to the EAP protected network and then creates direct ethernet/wifi link (can be hidden ssid maybe) between itself and the printer  - that could be probably also done with Raspberry Pi or some wifi routers with mikrotik/OpenWRT software on it.
Napsal : 27/03/2024 7:24 pm
