Cold Pull Not Working for Me
garylzimmer
(@garylzimmer)
I have a bit of filament stuck near the nozzle that I can't remove with cold pulls. I partially disassembled the hot end to clear a jam, and I think I didn't properly get the nozzle assembly far enough up the hot end and there's probably a gap where the filament is stuck. I only have PLA and I see that cold pulls are recommended with ABS.
Is there a different temperature I should do the cold pull at with PLA?
Do I need to completely disassemble the hot end and nozzle to clear the residue? Can you point me at a guide on how to do that?
Would this be solved by the all metal heat break from Bondtech?
Thanks!
This topic was modified 5 years temu by garylzimmer
Opublikowany : 04/11/2020 7:57 pm
ChillyPenguin
(@chillypenguin)
RE: Cold Pull Not Working for Me
The Prusa knowledge base is real very good, I find Google the easiest way to find anything.
https://help.prusa3d.com/en/article/clogged-nozzle-hotend-mini_112011
Opublikowany : 04/11/2020 8:29 pm
Posted by: @garylzimmer
Thanks!
Have you worked through the Prusa help manual yet?
Opublikowany : 04/11/2020 8:30 pm
@garylzimmer
Sorry, almost simultaneous post with same link. But double holds better 😊 .
Opublikowany : 04/11/2020 8:33 pm
