Changing The default Temp on the printer
zangeon17
(@zangeon17)
I have some PLA that I love that works in my Ender 3, it doesn't print well at 215, sometimes gets clogged in the extruder.
Is there a way of lowering the default PLA temperature on the machine? Mostly for loading, unloading and calabration
Publié : 02/03/2020 1:22 pm
keith.g5
(@keith-g5)
RE: Changing The default Temp on the printer
What post processor are you using.? You can change the filament there. If you are using Prusa Slic3r, click on the filament settings tab and make changes in the temperature settings. All tho I'm not sure the problem is temperature.
Ce message a été modifié il y a 6 years par keith.g5
Publié : 02/03/2020 11:06 pm
