Change layer calibration settings
polo5959
(@polo5959)
Hi Everyone,
Is there a way to have the layer calibration starting while the temperature of the bed and extruder is heating up? the Layer calibration seems unecesarly long...
Thanks,
Paul
Posted : 31/08/2023 11:54 pm
René
(@rene-3)
RE: Change layer calibration settings
Yes you can but then the leveling is not correct and therefore you run the risk of the first layer going wrong.
Similar question you asked earlier, with the answer to that can be found here. 😉
Posted : 01/09/2023 5:48 am
polo5959
(@polo5959)
Hi René,
Thanks, yes I know the 'why' it does this but I would like to know how to disable it, or modfy it, Is there a way to do it?
Thanks
Posted : 01/09/2023 10:04 pm
René
(@rene-3)
Yes you can modify that in the start G-code of your used Prusa slicer.
This can be found under the Printer Settings > Custom G-code tab.
You will then have to get familiar with the G-code commands before making any changes.
Posted : 02/09/2023 9:27 am
