Can't unload filament. Filament sticking out of extruder top
[Résolu] Can't unload filament. Filament sticking out of extruder top
dotMorten
(@dotmorten)
Tried printing with flex for the first time. After that wanting to unload, and couldn't, until I noticed filament was sticking out of the side in a big loop. Unload doesn't do anything, and I can't seem to pull it out either. What do I do here?
Best Answer by dotMorten:
Ended up following the assembly instructions for the extruder gears backwards, put the filament back in place, re-assembled and used a good pull to help it out on the next unload cycle, and it worked.
This is a good example of why I should have bought the kit and assembled it, and I would have known exactly what to do, and not have been this uncomfortable taking something apart.
Publié : 17/08/2021 4:40 am
dotMorten
(@dotmorten)
Fixed
Publié : 17/08/2021 5:17 am
Membre
Kit
The kit is good for that but you will be given ample experience repairing to learn this also.
Publié : 17/08/2021 9:55 am
