Cancel Object Grayed Out - Mini+ on 5.1.2 & 2.7.1 w/ binary on
I need to figure what is wrong with my setup that makes it so I cannot cancel objects. I have a Mini+ on 5.1.2 firmware and am using PrusaSlicer 2.7.1 with binary gcode on. I can find Cancel Object in the tune menu during a multi object print, but it is grayed out and I cannot use it. What could cause this?
Publié : 31/01/2024 10:25 pm
RE: Cancel Object Grayed Out - Mini+ on 5.1.2 & 2.7.1 w/ binary on
Just a guess. Do you have Print Settings>Output Options>Output file>Label Objects set to Firmware-Specific? If not, it won't work.
Publié : 31/01/2024 10:45 pm
Vous a aimé
Topic starter
answered:
No, it was set to OctoPrint comments. I will change it and give it a try. Thanks for the suggestion.
Publié : 01/02/2024 1:33 am
Topic starter
answered:
That worked. Thank you.
Publié : 01/02/2024 5:54 pm
