Can you use a half damaged smooth sheet?
Matt Orelup
(@matt-orelup)
Hello, just pulled a print off and a piece of the coating came off the smooth sheet.  Obviously this side is no longer usable, just wanted to make sure I could use it with this side facing down on the heatbed.
Veröffentlicht : 02/03/2022 5:41 pm
Friedhelm B.
(@friedhelm-b)
RE: Can you use a half damaged smooth sheet?
you can use the backside of your sheet, or you can place your models in prusaslicer around the damaged spot.
Veröffentlicht : 02/03/2022 5:54 pm
jsw
 jsw
(@jsw)
Yes, I had a smooth sheet that had one damaged side which I used for the better part of two years before the second side got hosed and I re-skinned it.
I used the damaged side for smaller parts.
In the photo below, the coating has been torn off to the top and left of the print.
Veröffentlicht : 04/03/2022 11:44 am
Bob
 Bob
(@bob-2)
Yes you can.  You can also continue to use that side so long as you plate your prints to avoid that spot.
While I've never tried it you may be able to resurface it with a PEI sheet.
https://www.prusa3d.com/product/pei-ultem-sheet/
This shows how to do it on the mk2/3 series
https://help.prusa3d.com/en/guide/replacing-the-pei-sheet-on-the-mk3s-mk3-mk2-5s-mk2-5_23920
You'd need to trim it for the mini and it should be a little easier with the steel sheet as you don't need to unfasten it from the printer.
Cheers
-Bob
Veröffentlicht : 04/03/2022 4:25 pm
