Boot stuck at the end of the loading bar FW 6.0.3
articnet
(@articnet)
Hello everyone.
Having an issue after flashing the new firmware.
When turning the printer on, with or without USB drive (tried both), I see the following:
- initial "Bootloader 2.3.4" screen
-loads to half
- white flash
- "Firmware 6.0.3+14902" and loads to the end of the loading bar
stuck here.
Switch off.
Turn on again, it works.
Switch off.
Turn on again, stuck at the end
Switch off.
Turn on again it boots.
I tried a Hard reset, tried changing usb drive, tried everything I could think of. Any idea what I could do?
Posted : 03/07/2024 5:18 pm
GUEROH
(@gueroh)
RE: Boot stuck at the end of the loading bar FW 6.0.3
I am at the same place you were in March. I am stuck. Were you able to fix it? What steps did you take?
Posted : 16/07/2024 1:13 am
GUEROH
(@gueroh)
Update: Got on tech support. Got Alfredo C and he was awesome. He helped. We tried a few things.
We tried the flash erase procedure which is 1. Press reset 2. Immediately after press the knob for 1.5 seconds and let go 3. There will be a screen that comes up as 'Erase'. If you get the verifying firmware or the bootloader starts to load you have missed it. Start again.
This did not work for me. I kept getting stuck on the final step of loading the firmware. We proceeded to load older firmware. We loaded 5.1.2 and that did not work for me. We stepped it even further to 4.4.0 and that worked. After which I upgraded to 6.0.3. It hung at the last step but after a quick reboot 6.0.3 finished its processes and I was up and running.
Hope this helps someone.
Posted : 16/07/2024 3:02 am
