Bondtech Upgrades: Flow/Speed Settings
unknwnrider
(@unknwnrider)
For those whom have upgraded to the Bondtech extruder or heat break, have you adjusted any flow/speed settings?
Since the heat break is shorter, is less retraction required? Noticing some under extrusion. Not sure if I’m not flowing enough or retracting too much.
thank you!
Publié : 24/04/2020 6:33 pm
Patrik
(@patrik)
RE: Bondtech Upgrades: Flow/Speed Settings
I've been using the Bondtech heatbreak for about a week and the only change needed was to put in the PID values (M301 P13.54 I0.98 D46.58) ,recommended by Bondtech, in the start G-code for the printer.
All the filaments have been behaving since the upgrade.
Publié : 07/05/2020 2:27 pm
Oxygen
(@oxygen)
I have followed you advise and ordered the heatbreak also, is there a document included or did you find the PID values somewhere else? (if so please include link)
thanks for the tip 🙂
Stock MK4S with FW 6.2.6
Publié : 07/05/2020 3:52 pm
Patrik
(@patrik)
Here's a step-by-step guide for the heatbreak: https://support.bondtech.se/Guide/0.1+Heat-break+Upgrade+Kit/60?lang=en
Publié : 07/05/2020 4:47 pm
Oxygen
(@oxygen)
wow, thank you -- going to study that while the package is finding a way to my home 🙂
Publié : 07/05/2020 7:10 pm
