Bondtech extruder stopped moving soon after install
[Gelöst] Bondtech extruder stopped moving soon after install
WillDeed
(@willdeed)
Hi all,
I upgraded a few things on my Prusa Mini this weekend, but I'm having issues with the new Bondtech extruder. I'm hoping I can get some troubleshooting advice.
What I upgraded:
  1. Mini+ Upgrade (replaced the MINDA with the Super PINDA)
  2. Bondtech Dual Drive Extrusion Upgrade
  3. Bondtech Heat-break Upgrade
The extruder upgrade was done according to the instructions:
  1. Swapped out the extruders, offsetting the new brass motor gear with a zip tie
  2. Swapped the red/blue pins on the connector to the main board
  3. Installed the thumb screw and backed it off by 4 turns
  4. Adjusted the estep by adding "M92 E415" to octoprint via Terminal and PrusaSlicer
I then started doing some z-level calibrations, and everything looked fine. However, during the second calibration print, the extruder stopped pushing the filament.
I tried:
  • unloading/loading filament
  • Restarting the printer
  • Reinserting/adjusting ptfe
  • Tightening/Loosening the thumb screw
None of these fixed the problem. I can manually push the filament through the extruder, and I can see the motor turning normally. The filament doesn't move at all though, which makes me think it's not engaging.
Has anybody else had this issue? Any ideas on what I can check?
The only thing I can think of is if maybe the motor gear wasn't tight enough and slipped?
Thanks in advance for ideas.
Best Answer by FoxRun3D:
Haven't had that with any Bondtech extruder but if you can manually push it through it's not a clog, and you said the motor is running, so all that's left is two things:
Most likely, the gear is not properly installed on the motor. Check the set-screw. Make sure it's properly installed per step 19 in the instructions.  Tight against the FLAT side of the shaft. I guess it could also be installed in the wrong orientation, which I managed to do once (albeit on a Mk3S).
Or the idler (thumb screw) is not tight enough.
Beyond that, I don't see anything else that can be wrong. My money is on the set screw.
Veröffentlicht : 07/09/2021 2:44 am
Veröffentlicht : 07/09/2021 11:34 am
WillDeed
(@willdeed)
Re:
Yep. It turned out to be the set screw. I missed that there is a flat face on the motor, so I must not have used it and it loosened up to where it was basically a bearing at that point.
Tightened it up and it's running smooth now. Thanks for the reply fuchsr!
Veröffentlicht : 07/09/2021 5:58 pm
Happy to help!
Veröffentlicht : 07/09/2021 5:59 pm
