Bad layer adhesion related to layer height
Ignat Todorov
(@ignat-todorov)
Mitglied
Hey fellas, I'm using a Prusa Mini with a 0.8 mm nozzle. Recently with a Layer Height of 0.6 mm the layers can't bond. With a Layer Height of 0.3 mm the layer adhesion is better but not perfect. I printed the same object with the same settings on another Prusa Mini and the print went perfectly.
I changed the nozzle with another 0.8 mm nozzle, changed the PTFE tube in the hotend, squared the axis, regulated the belt tension and the problem persists. Any idea what is causing this?
Veröffentlicht : 25/09/2024 11:53 am
_KaszpiR_
(@_kaszpir_)
RE: Bad layer adhesion related to layer height
Please provide more details about the profile used in PrusaSlicer used for that nozzle.
Veröffentlicht : 26/09/2024 6:34 am
Ignat Todorov
(@ignat-todorov)
Mitglied
Sure, I'm using the "0.55mm DRAFT @0.8 nozzle MINI" preset from Prusa Slicer for the print.
Veröffentlicht : 26/09/2024 11:03 am
