Axe Y bloqued unbloqued…
Hello, I have an Issue with my Mini. The Y axis randomly blocks. I’ve trouble moving the heating plate manually. I’ve checked the belt tension, disassembled the motor to check that there is no blocked filament… Everything seems good. The Y axis test fails. Sometimes it starts then fails. Sometimes the test the motor does not even turn. Thanks in advance for your help.
Janro
Napsal : 20/10/2024 6:55 pm
Topic starter
answered:
RE: Axe Y bloqued unbloqued…
I took the motor apart and I think one of the bearings is dead.
Napsal : 20/10/2024 7:42 pm
