Automatic gradual change print speed as print gets higher settings
I printed this to the max height for the mini+ in vase mode, it's very smooth in the bottom half but starts to waver the next. Is there a way to gradually slow the speed as it gets higher in the slicer?
Posted : 07/04/2023 9:10 pm
RE: Automatic gradual change print speed as print gets higher settings
I've never tried it but you put some custom g-code in PrusaSlicer before or after layer change to change the speed. There is a good discussion here https://forum.prusa3d.com/forum/postid/206942/
MINI+ with FW:4.3.3, Bondtech IFS Extruder, drilled out PC4-M8 couplers, 1 piece Capricorn bowden.
Posted : 15/04/2023 12:46 am
Topic starter
answered:
Thanks, I'll check it out
Posted : 15/04/2023 6:08 am
I ended up writing a short python method to do just this: https://gist.github.com/alepetri/8fd9f99316aa6e4fd9917fa7819bac0e
Posted : 03/08/2023 1:30 am
