Add filaments to the "load filament" option on the printer
Nathan Domier
(@nathan-domier)
This feels like a silly question, but after 30+ minutes of searching I still can't find an answer.
How do I add more options to the "Load Filament" menu on the mini?  I'm trying to print with TPU but it's not an option.  I can pick something with a similar temps, like PVB, and the printer will load fine, but then when I go to print something set for TPU in Prusa Slicer the printer complains that I have the wrong filament loaded.  (Because, it won't let me select TPU as a filament when I load the filament.)
How do I add more options to the load menu to avoid this?
Best Answer by Neophyl:
You can't make changes to the menu options on the mini itself.  Well not without customising the firmware, compiling it and flashing your new custom version to the printer.
Opublikowany : 11/07/2024 6:51 am
Pick the closest existing profile, make all the changes you desire, then click the icon next to the filament name ('save') and give the new preset a meaningful name.
It will be added to the bottom of your filaments list under 'User presets'.
Opublikowany : 11/07/2024 12:03 pm
RE: Add filaments to the "load filament" option on the printer
Opublikowany : 11/07/2024 12:19 pm
Well spotted @neophyl, I misread that as a slicer question.
Opublikowany : 11/07/2024 12:22 pm
mark
 mark
(@mark)
Load Flex on the Mini. That works for TPU without complaint for me.
Regards,
Mark
Opublikowany : 11/07/2024 3:00 pm
1 ludzie polubili
Nathan Domier
(@nathan-domier)
Thanks all, as expected I was asking the wrong question.  Because the filament settings in the G-Code override whatever the filament was loaded as on the printer, there's not necessarily a need to add new options on the printer. (as I was trying to do)
I'll try loading it as Flex next time as suggested so that I can avoid the errors on printing.
Opublikowany : 12/07/2024 2:48 am
George
(@george-4)
Yeah, its what i do if i want to print with ColorFabb's PET-HT. the temps are closer to ASA, so when i load it up i use that one. And then when the file gets loaded up and the printer says "hold up, you have the wrong filament loaded" i just tell it to go ahead anyway.
I would also love it if there was a way to put more filaments in the load section, just so that it wouldn't complain.
Opublikowany : 16/07/2024 6:31 pm
