[Solved] 15 mm long PTFE tube?!?!
Ford Prefect
(@ford-prefect)
Is there any location where a 15 mm long PTFE tube is used in a mini?
I found this tube....   :-/
Napsal : 18/02/2021 6:29 pm
Ford Prefect
(@ford-prefect)
RE: 15 mm long PTFE tube?!?!
Solution found together with customer service:
The very short PTFE tube goes into the brass fitting, which sits in the extruder.
Step 36 more or less....
Prusa Knowledge Base | 3. X-axis & Extruder assembly (prusa3d.com)
Napsal : 18/02/2021 8:30 pm
