Selecting Additional Build Plates
I have a MK3S+ and on the latest software I still have only Textured or Smooth to choose from - is there a way to “Enable” or “Add” additional build plates so that they show up in the printer screen to select - I have a Satin build plate that is slightly different thickness to the Texture and Smooth so would like the option to select it with its predetermined Z offset like the smooth and textured have and away I print rather than faffing about with the Z each time.
Veröffentlicht : 26/08/2024 6:23 am
RE: Selecting Additional Build Plates
In the printer's LCD menu, go to Settings>Hardware Setup>Steel Sheets, where you can do a first layer calibration for each sheet and give it a separate Z value.
Veröffentlicht : 26/08/2024 8:49 pm
