Prusa Slicer 2.9 - not respecting object order in object list
Nscale_toni
(@nscale_toni)
Membre
Hey all,
Just wondering if I am doing something wrong or if there is a bug in the slicer.  I am trying to do a multi color print & have two objects that I want to use to prime/purge the nozzle before the color change.  These should be printed first before the rest of the objects on the printbed.  Unfortunately, even though I have them at the top of the object list, they seem to get printed in some random order.  The order will change depending on where I place them on the bed.   Have looked for a solution in the knowledgebase, but it just says to drag the object to the top of the list ...
Thanks
Publié : 23/02/2025 6:14 pm
Ratchet
(@ratchet)
Membre
RE: Prusa Slicer 2.9 - not respecting object order in object list
+1
Hi all,
Same problem for me. I already tried :
  •  Uninstall PrusaSlicer 2.9.1
  • Run Ccleaner
  • Install PrusaSlicer 2.9.1
This did NOT work for the linked project : The_problematic_3mf
It does work for "simple" project (i.e a cube and cylinder).
It seem it does systematically not work for the linked project.
Any potential fix/correction/work-around ?
Thanks,
Xavier
Publié : 10/04/2025 12:05 pm
LarGriff
(@largriff)
Yes, it’s buggy.  Sometimes it works by fiddling around… try moving other items to the bottom instead of your desired items to the top.  Sometimes PS totally crashes when I do that and I have to start over, so save often!  I hope they fix it soon!  It matters for my projects that use a freeze frame camera.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Publié : 12/04/2025 3:24 pm
