Problem with offset :/
Hello,
I still have the problem with my Artillery Genius (often but not always) that where there is a surface, there is a slight offset on the outer wall.What can this be due to? Flow is calibrated, extruder is calibrated.
Do not know if you can see it well now with my Oreo box, where the top of the plane surface above is and at the grooves on the outer skin the rounding begins is a slight offset, have two cookies at once (0.2 layer height) printed at one is the offset to the left at the other to the right, so I can not imagine that it is a problem with the axes.The whole is once completely around the cookie.
(PHOTO: Once cookie top/bottom).
Thanks in advance.
Publié : 15/07/2021 12:16 pm
Publié : 29/07/2021 2:59 am
